Farmall Tractors Discussion Board
Re: A Hard Starting Farmall Cub
Posted by ltf in nc on August 10, 1999 at 19:53:20 from (206.228.213.171):
In Reply to: A Hard Starting Farmall Cub posted by Scotty on August 10, 1999 at 09:56:55:
If the compression is so bad that it will not start by cranking with the starter it would still run by pulling it off. There is something else wrong. Somehow you are out of time, got gas that is no good or has water in it, or the spark is intermittent, etc. The last time I mentioned this I got flamed for wasting parts but I am going to repeat the suggestion. Take the valve cover off, verify that you are on the compression stroke and that the timing is correct. Verify that all the valves are functioning and that the cam is not broken. Get a sample of the gas on some tissue paper a light it to see that it burns readily. Check each plug independently to see that each one is firing. When all the above is correct I believe the tractor will run by pulling it off. Do check the compression as suggested and if it is fairly uniform and up around 95+ psi it should crank off the battery. Posts your results so that we all can learn. Good luck
Post a Followup
: Re: Re: A Hard Starting Farmall Cub
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
