Re: M Remote Hydraulics
Posted by Haas on June 09, 2002 at 05:50:51 from (166.72.245.188):
In Reply to: M Remote Hydraulics posted by Doc on June 08, 2002 at 15:06:55:
The M belly pump does not put out any pressure unless you pull pack on the control rod. Thus is you have a two way valve on their (like the NOS valve you added) then you have to lock the belly pump rod in the lift position to use the two way valve. This causes fluid to flow through the two way valve all the time, but the fluid just goes out the bypass of the two way valve back to the reservoir unless you operate the two way valve lever to lift your implement. Oil flows through the lift all pump all the time anyway, but it bypassed internally when the control rod is forward it you don't have the external remote valve. With the external valve, you are just changing the way the system bypasses.
Post A Followup
: Re: Re: M Remote Hydraulics
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
