Oil passages on 1940 H
Posted by Dan in Texas on March 26, 2003 at 15:51:54 from (209.151.96.69):
Is there a way to blow out the oil passages on the engine without disassembling it? I took my oil filter base off and it was really a mess inside. The base doesn't have the relief valve and the badly deteriorated filter was laying in the bottom of the filter base. I don't mind taking off the oil pan and valve cover. Does the engine need this spring and valve in the base? I'm sure some of this crud got into the passage going into the engine from the filter. Also, I checked the compression and it was within 15 psi of each cylinder. Does anyone know what good compression is on a 1940 H? Thanks in advance!
Post A Followup
: Re: Oil passages on 1940 H
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
