Re: Oil passages on 1940 H
Posted by Theman on March 27, 2003 at 10:19:11 from (12.19.86.5):
In Reply to: Oil passages on 1940 H posted by Dan in Texas on March 26, 2003 at 15:51:54:
Dan, the oil filtration on the H is not full-flow. It merely takes a portion of the oil in the main gallery and filters it then dribbles it back into the oil pan. The filter base doesn't have the relief valve in it. The pressure relief is built into the oil pump. The only thing to check in the filter canister is the small hole in the long bolt. That is the return of the filtered oil into the sump so make sure it is not clogged or you will have no filtration. That said, if your engine has been running OK for a while there's a good chance nothing is plugged. Beside the valve cover and pan, you can remove the governor cover and check in there too. The governor is the end of the line for the front portion of the engine. Oil there would tell you that part is OK. The rocker arm assembly is the end of the line for the center cam/main bearing branch of the circuit. Oil should be at the pivot point of each rocker arm. Were the tractor mine, after checking under the covers, two oil and filter changes about 20 hours apart would be about all that's necessary.
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
