Switched on B?
Posted by Rauville on May 22, 2003 at 08:25:06 from (209.180.79.141):
Just purchased a cheap old IHC B with mower, and see that at sometime in the past someone added a second push / pull switch wired into the generator as a cut off. Is there any reason that you would need this if the voltage regulator is working? Thanks from SD
Post A Followup
: Re: Switched on B?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
