Re: Re: Re: HELP qiuck--400 REALLY stuck in gear
Posted by Hugh MacKay on June 29, 2003 at 18:46:58 from (64.228.12.29):
In Reply to: Re: Re: HELP qiuck--400 REALLY stuck in gear posted by scott on June 29, 2003 at 17:30:23:
Scott: You have told me a lot this time by saying what you were doing when this happened. The fact the tractor started to stall indicates you have two gears engaged. Of the three slides which one would you estimate is in neutral? This usually doesn't happen when shifting from 2nd to 3rd. Those three rails that your shift lever operates in are as follows; left is 4th and 5th, center is 2nd and 3rd and right is 1st and reverse. The transmission cant get in two gears that are on same rail. This usually happens when shifting from 1st to 2nd or vice versa and shifting from 3rd to 4th or vice versa. What usually happens is end of shift lever is worn and slips out of notch in rail without removing from a gear then you put it in a gear on next rail. If you study your shift lever movments below deck, you can fathom which gears you have tractor in. The next thing I would try is another vehicle that will move tractor enough to take presure off gears. The ideal item would be a set of come alongs as you have to remove presure off gears. The reason the clutch didn't help is the two gears at once. You may have to try pulling both foreward and reverse and hold. One way will release that presure. This should work, and after you get it freed up the end of shift lever should be built up with weld and ground off so it nicely fits the notch in one of the rails. One other item I notice your clutch and TA need adjusting. This should be by the book exactly. Close doesn't count. I do hope this helps, if not come back.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
