Re: Farmall Super C charging problems
Posted by Bob M on August 06, 2003 at 12:44:11 from (165.170.128.65):
In Reply to: Farmall Super C charging problems posted by John N_PA on August 06, 2003 at 11:42:29:
John - Presuming you have distributor ignition (not a magneto) the motor will indeed quit once the battery runs down, just as you observed. Normal ammeter readings vary depending on engine speed and the battery's state of charge. At full RPM it will read about +12 to +15 amps with the battery is low and taper to about +5 once the battery becomes fully charged. At idle it however will read -2 to -4 amps regardless of the battery's charge level. If you are seeing an intermittent charge on the ammeter with the motor running at full speed, problem could be a loose generator belt, poor ground at the voltage regulator or a problem in the generator itself. Suggest checking/tightening the belt then making sure the regulator is base is solidly grounded (mounted to bare metal and mounting screws are tight). If that doesn't correct the problem, use a jumper wire to temporarily ground the "F" terminal at the voltage regulator with the motor running at full RPM. If the problem persists with the "F" terminal grounded the generator needs repair. Good luck!
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
