Re: Re: growler/ armature check
Posted by rebuilder on January 08, 2004 at 18:35:51 from (216.241.134.123):
In Reply to: Re: growler/ armature check posted by Allan on January 08, 2004 at 17:35:41:
Allan;
No, you are correct. I use a large diameter light washer to feel for shorts. Most are pretty obvious, but I have had some armatures come back after rebuild where a short showed up.I wonder whether a slight short goes undetected? Also on my tester there are continuity leads to check for shorts between the commutator(copper) and the steel. You memory serves you well. I had to teach myself how to use this when I first started rebuilding a few years ago.
Post A Followup
: Re: Re: Re: growler/ armature check
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
