Re: Re: Re: Farmall M won't stay running
Posted by don on March 11, 2004 at 18:32:46 from (67.39.30.118):
In Reply to: Re: Re: Farmall M won't stay running posted by Jeremy on March 11, 2004 at 16:50:53:
How fresh is the gas? if it's over a year old forget it. If the gas is new put your hand over the carb intake if no suction your valves are not sealing off and that could be caused by setting too long because they may be stuck open which is common if you listen you can hear a sucking sound coming from your exhaust pipe while engine is being turned over. This is a very common occurance especially if the exhaust has not been covered up when outside during long periods of not running.
Post A Followup
: Re: Re: Re: Re: Farmall M won't stay running
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
