Re: Re: Re: Re: Farmall M won't stay running
Posted by Allen Bishop on March 12, 2004 at 21:42:24 from (64.136.26.230):
In Reply to: Re: Re: Re: Farmall M won't stay running posted by don on March 11, 2004 at 18:32:46:
Okay, here it is. I just got through doing the same thing to my 1940 M.. New carb and all. First screw the air mixture screw(the one on top) all the way in, then back it out 1 and 1/2 turns. Next turn the fuel screw (the one on the bottom in front of the carb) all the way in and then back it out three full turns. Now this is very important. Take the bottom bowl off of the carb and on the float there is a little flap on the front side of the carb that keeps the float from going all the way down. bend this down just enough to let the float fall down about 1/2 inch before the flap stops it. This way the float won't go down too far and stick and let your gas overflow out the intake. Now that you have that done, check your oil. If it is overfull, or if is smells the least bit like gas, drain it because it got gas on top of the cylinders from the intake manifold and it washed down the cylinder walls, and you won't get compression, and you won't have any oil up there. take the spark plugs out, and squirt some motor oil onto the top of the pistons, then turn the motor over several times to lubtricate the cylinder walls. Put the plugs back in and turn the gas back on under the tank and chances are , after possibly having to crank it for awhile, it will run like a swiss watch. I don't even have to choke mine now and don
't have to turn the gas off anymore when I shut it off. Hope this helps. Allen
Post A Followup
: Re: Re: Re: Re: Re: Farmall M won't stay running
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
