Re: M Throttle lever adjustment
Posted by Wild Horses on May 04, 2004 at 08:25:59 from (216.51.163.251):
In Reply to: M Throttle lever adjustment posted by jamie on May 03, 2004 at 10:45:09:
The play between the governor lever and the throttle is caused by two opposed springs in the linkage at the arm that is up by the valve cover. This allows a little movement of both throttle and governor against the other's position. As for the RPM limit, I'd check the stop bolt inside the governor first. There is a bolt in the front arm inside the governor that comes against the housing, stopping it from opening farther. This was used to set the WOT. Very few M's will stay at WOT. Most will back off slightly. Are you using a friction disk or toothed throttle? The friction disk may need changed out or the spring tightened down with a washer. With a weak spring, the tractor would often bounce and jostle the throttle causing it to shut down. Aside for that, I'd also check the governor spring. It could have a stiffer spring that is pulling against the throttle.
Home
| Forums
Today's Featured Article -
A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
