Re: Farmall A problems (novice)
Posted by Haas on July 19, 2004 at 06:12:53 from (12.65.18.237):
In Reply to: Farmall A problems (novice) posted by Andrew on July 18, 2004 at 19:33:58:
If the leak is around the head gasket, I'd try removing the valve rocker cover and the rocker arms shaft assembly and retorque the head bolts. It's necessary to remove the rockerarms and shaft to get to the head bolts. You'll have to reset valve rocker arm clearances when you reinstall the rocker arm assembly. Get a new gasker for the cover and also make sure you align the notch in the rocker arm shaft with the stud bolts when you reinstall. I've seem some specs that say 60 ft-lbs for the head bolts and others say 80. I've always used 80. If retorqueing does not stop the leak, they you will need to replace the head gasket. All this assumes you do not have a crack in the block or head. Usually a crack in block is just in front of carburetor on the side of the block. That does not sound like yours. As to the lights, you will just have to trace down the wiring. Could be a bad switch or bad ground.
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
