Re: Noise in 706 rearend
Posted by K.B. on July 21, 2004 at 20:42:22 from (209.163.30.84):
In Reply to: Noise in 706 rearend posted by Brian on July 21, 2004 at 12:23:29:
You've definetly got a tooth knocked off the reverse driven gear, caused by someone dropping it in to park while it was still moving. You can either remove the reverse idler cover from the left side, or remove the range trans cover/shift deck underneath the platform to inspect it. It is the rearmost gear on the top shaft. It is a big job to replace it, but it is pretty easy. If you can handle a JD Syncro-Range, you can definetly handle a 706. You will need a few special tools.
Post a Followup
: Re: Re: Noise in 706 rearend
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
