Re: harmonic balancer questions
Posted by K.B. on July 28, 2004 at 17:40:20 from (209.163.30.70):
In Reply to: harmonic balancer questions posted by Dan on July 28, 2004 at 06:06:37:
You got good advice from Allan and Bob. I've always been told that if the rubber ring between the inner and outer pieces shows any signs of cracking or swelling, the balancer needs replacing. If you beat or pull on the outer ring, it is junk. Also, the outer ring of the balancer can "slip". The best way to check for this is to mark the relationship of the inner and outer pieces by drawing a line, put 20 hours or so on the engine, and you will be able to tell if it is slipping. Like Bob said, some engine manufacturers tell you to replace it every so many hours. I've never seen anything from IH, but I think John Deere says 5000 hours for some of their engines. If in doubt, just replace it. When the balancer fails, somthing else is going to break. I once saw an engine that failed due to a broken camshaft. The pistons hit the open valves, and the pushrods were "S"-shaped. What caused the camshaft to break? Vibration- the dampner was found to be in two pieces.
Post a Followup
: Re: Re: harmonic balancer questions
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
