Re: IH W-9 Engine
Posted by tony on August 19, 2004 at 16:22:01 from (12.28.24.70):
In Reply to: IH W-9 Engine posted by craig ingram on August 19, 2004 at 12:58:15:
I just pulled the engine on my o4 probly the same procedure. first take all the sheet metal off . remove rad. gastank, aircleaner , clutch housing cover . remove clutch and flywheel to expose the bolts in back of the engine. dont try to remove the engine with the plate still attached the pins will be stuck and youll break the plate trying to remove it with the engine attached too it. remove the bolts from back of the engine and the two big nuts under the front pulley and it should come out . note.. under the front nuts is shims be shure to keep track of how many is under each nut!!! hope this helps
Post a Followup
Subject:
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
