Re: Hydraulics on 560 running
Posted by captaink on September 13, 2004 at 08:38:43 from (66.115.214.56):
In Reply to: Hydraulics on 560 running posted by Donny on September 13, 2004 at 06:33:08:
Joe’s reply is right on the mark unless one of the two following is causing the “running” you describe. If one of the remote valves (where you set it for either double or single acting cylinders) is in a bad position it will cause the “running” condition you describe. If you have changed any of these lately because of changing types of cylinders used on the remotes, this might be the cause. Try turning them to a slightly different position to see if the “running” stops. If so, you have found the cause, now you just need to play with the setting until the cylinder works correctly and the “running” is gone. This one is not as likely but can happen. If the “running” stops with the fast hitch somewhere between all the way up and all the way down, then the stops for the touch control lever for up and down are adjusted to a position that is impossible for the hitch to get to. This adjustment is regulated by the two set-screws “stops” for the lever that actuates the fast hitch. In this case you need to screw them in further so that the lever stops while the cylinder is still in the range where the position you have selected is obtainable. Hope this helps.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
