Re: Timing Marks on Super C Farmall
Posted by Bob on September 27, 2004 at 10:02:37 from (66.163.134.177):
In Reply to: Timing Marks on Super C Farmall posted by Scott Swanson on September 27, 2004 at 09:28:48:
I'm not sure, but if the engine has been replaced with a certain stationary power unit engine, there may be a timing pointer at the front of the engine, and a mark on the front pulley, or you just may not be seeing the flywheel marks. However, even without visible timing marks, initial timing is easy to set. If you're hand cranking it, you do not want spark before TDC. Certainly, not more than a few degrees before TDC, in any case. Keep the ignition switch "OFF". Remove the #1 spark plug. Crank it over until you can feel compression beginning to build, as you hold you finger OVER the spark plug hole. This indicates it is coming up on TDC of the firing stroke. Disconnect the primary distributor lead from the coil and hook a battery powered test light or an ohmmeter to the primary terminal on the distributor and ground. Either one will show continuity, because the breaker points are closed. Use a plastic straw or similar probe stuck down the sparkplug hole, which will rise as the piston comes up to TDC. The test light should go out (or the ohmmeter will read "infinity') just as the piston reaches TDC, if the points are opening at the correct time. Now that you've got the engine at TDC, take another look for the timing marks, now that you know where the should be. Make your own TDC mark, if necessary, for next time. If the points are opening before that, correct the position of the distributor, and try again until you have the points opening reliably at the TDC point. I'm not sure what the spec. is, perhaps 4 degrees BTDC, but if you're going to hand-crank it, TDC is safer. Disconnect your test light or ohmmeter, reconnect the primary lead to the coil, and you should be all set.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
