Farmall Tractors Discussion Board
Re: Super A Charging System
Posted by Curt Cooke on November 20, 1999 at 15:48:00 from (207.75.224.75):
In Reply to: Super A Charging System posted by Stan on November 20, 1999 at 15:34:29:
Stan, start by making a jumper wire. With the tractor running, attach one end of your wire to the F terminal on the generator and the other to a good ground (use the grounded side of the battery)that way you're in a position to read your gauge. If the gauge jumps to the charge side, the problem is with the regulator. If it doesn't, the problem may still be the regulator. If nothing happens, remove the cover from the regulator. With your ground wire still in place, close the contact points on the solonoid that are the hot ones. If the contacts stay closed and the guage does not move to charge, you have a problem with the generator. If things move like they should, you may be able to adjust the field circuit solonoid in the reg or maybe the reg isn't grounded or maybe the reg is shot. I too am in Southwest Michigan Stan, feel free to give me a call.
Curt Cooke
Hudsonville, MI
616-669-0486
Post a Followup
: Re: Re: Super A Charging System
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
