Re: OT, 93 F-350 Diesel problem
Posted by Bob on December 02, 2004 at 15:25:57 from (66.163.134.177):
In Reply to: Re: OT, 93 F-350 Diesel problem posted by ChadS on December 02, 2004 at 15:09:05:
The cam on the throttle shaft is set using an angle gauge. I don't have specs at hand, though. The more you screw the Allen-head screw in at the bottom of the lever, the more the timing will retard. Outside of a test stand, I'm not sure how to accurately set that. Are you aware of the HPCA solenoid (Housing Pressure Cold Advance)? This is the second wire attached to the pump cover, more rearward as it sits in the pickup. There is a thermal switch near the thermostat housing that supplies battery voltage to that second terminal when the engine coolant is below about 129F. That solenoid dumps pump housing pressure, causing the cam ring to advance for better starting, and clean running at startup. If that system is working, there will be extra diesal rattle at startup until the coolant temp comes up, and then it will abruptly retard a few degrees. This is also hooked to the high idle solenoid. If the HPCA system is not working, there will be more smoke and rough running at startup. Have you noticed if the advance and/or the fast idle are working? Did you take a look at the fuel lift pump, for possible weeping and leakage that might also inducate fuel is leaking into the crankcase?
Home
| Forums
Today's Featured Article -
Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
