Please Help///Re: engine dies when mower engaged
Posted by Cobrajet on April 05, 2009 at 08:26:01 from (74.131.78.132):
In Reply to: engine dies when mower engaged posted by Cobrajet on April 03, 2009 at 16:48:43:
hello all! i tried all suggestions today with no luck..
No vacum leaks around carb or intake. installed new gaskets anyway.
opened carb up again re-did all internall parts again.
pulled all plugs re-gapped .025
points re-gapped .020
firing order 1-3-4-2
button does turn clock wise if that helps?
tank drained "clean no rust"
fuel bowl clean.
new screan.
gas line free and clear.
filter at end inside of carb free and clean.
when gas line off gas runs freely.
when on carb and bolt removed runs freely.
also tried to rotate distributor minimal change.
im at a lose!!!! Im sure it will be somthing very simple that i've missed.
All parts are new. cap/rotor button/plugs/wires/points
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
