Re: H not charging
Posted by Bob M on April 30, 2005 at 13:56:56 from (69.205.121.248):
In Reply to: H not charging posted by ron 55 on April 30, 2005 at 13:35:49:
Ron - A few thoughts...
It's not likely anything was damage by the A and F wires being reversed.
You are correct that you should see 7-1/2 to 8 volts or so at the battery if it's being charged by the generator.
Your resistance reading across the cutout contacts is way out of whack! It should read 0 ohms (or perhaps 0.1 ohm if you have a good DVM). Your reading of 12.5 ohms says the cutout bad.
You might try lightly filing the cutout contacts and see if you can get the resistance down to 0 ohms. However my recommendation would be to get rid of the cutout and replace it with a voltage regulator. A regulator elimates the field resistor on the light switch, and does a much better job of maintaining the battery.
Hope this helps!!
Post a Followup
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
