Re: Procedure for adjusting valves on M?
Posted by captaink on July 22, 2005 at 05:56:58 from (66.115.214.56):
In Reply to: Re: Procedure for adjusting valves on M? posted by Bobg on July 21, 2005 at 20:07:12:
Compression in the way you are referencing it is the amount of pressure that it created by the piston in the combustion chamber when it comes up on the compression stroke. The higher the pressure, the tighter the valves in the head and compression rings on the piston are sealing, which relates to more of the explosion of the fuel being contained and turned into power output. Another reference to compression is the compression ratio. This is the difference between the volume of the cylinder when the piston is at the bottom of its travel and the volume of the chamber when the piston is at the top of its travel. For a close example in a 282 Diesel engine each cylinder has approximately 70.5 cubic inches of volume with the piston at the bottom of the stroke. If memory serves me correctly, the compression ratio on the engine is 16:1 which would mean that at the top of pistons travel there is only about 4.4 cubic inches of volume. Of course it takes a lot of energy to squeeze air because the pressure inside the cylinder increases dramatically which is necessary in a Diesel engine as this heat is the ignition source for the fuel. This might be more than you wanted to know, or might raise other questions. Holler on the board if it did and someone here will answer.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
