Re: Dead H-clutch/tranny?
Posted by RustyFarmall on October 31, 2005 at 07:21:40 from (199.120.81.250):
In Reply to: Dead H-clutch/tranny? posted by Matt from MN on October 31, 2005 at 06:54:37:
Most likely the tractor is still in gear. Pull the shift lever out and look down in that hole and see if the three shift rails are all lined up. Probably the shift lever is worn down on the bottom end, and you didn't get the transmission completely into neutral and it just sort of shook itself into gear. It is possible that something more serious happened, but let's not go there until you have checked out the easy fix.
Post a Followup
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
