Re: loose sleeve
Posted by the tractor vet on November 03, 2005 at 05:44:05 from (4.124.75.201):
In Reply to: loose sleeve posted by john rennie on November 02, 2005 at 21:03:09:
Now if i was doing it i would have the block bored and install a repair sleeve and bore to fit the loose one as they should be a press fit not had fit . Now as the guy with the 460 diesel that had one that was a hand fit yep they will end up in the pan every thime and when doing a rebuild on a 6 cylinder gasser or diesel on the the top of the block you will see a stamping of either A-B or C-D this the BORE class of that hole and the kits you get from after market only fit A-B class holes and if ya use them in a C -D hole they will be loose and will find there way to the pan and yes some guy will use LOC TIGHT but i won't as the heat from the engine can melt the LOC TIGHT and then if i am doing the engine and a sleeve comes out WHO gets to fix it again at my expence . If a sleeve is loose i either get the correct sleeve or bore and re sleeve to fit and then you are done with it .
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
