Water good , in oil -bad ! ( long )
Posted by Randy-IA on November 04, 2005 at 16:30:43 from (209.152.95.37):
Hi all , I took the drain plug out of the M . About a cup of water came out before the sludge started which by the way looked like whipped milk . So I removed the pan . It all look's good up in there but the oil pump pickup was about 99% plugged with gunk and grass and yuk . Took it apart and cleaned it . The bottom of the piston's don't have any burned on oil deposit's and the sleeves looked shiney , no crosshatch left but also no serious wear mark's or scratches as far as I could see so I put it back together and filled it with oil and started it up . The pan doesn't leak but the front crank seal does . Is this a doable fix with the motor still in the tractor ? I also drained some gear oil out of the front of the transmission and guess what ? Oil looked like whipped milk ! Water is in everything ! I know that the antifreeze can't make it to the final drive so I'm hoping the water in both of them was just condensation . There was new antifreeze in the motor when I brought it home and it doesn't appear to have dropped any but I haven't ran it much either . 13 Gallon's of gear oil ! That'll empty out the bank account ! But maybe it'll quiet the beast down on the road . All 9 gear's work good but it growl's going down the road which might be because the gear oil was so low in the box that I couldn't see it through the check hole with a flashlight AND it has water in it . I'm just going to put new oil in it and if it doesn't all run out onto the ground I'm going to run it that way till I get around to fixing it right , maybe next year . It also start's very easy so far but it does miss at low rpm's to about 1/3rd throttle . 1/2 throttle on up it seems to do OK with no load but since I ripped off the muffler to get the thing home without it breaking off it spit's fire when it miss's and when it's moved to wide open very fast . I haven't checked out the the hydrualic oil yet ( I suspect there isn't any ) and the belt pulley won't engage . It doesn't actually have the pulley so that's something I'll have to scrounge up sometime . All in all , if the crankcase doesn't fill up with antifreeze , I'm satisfied . Now I think that I did my normal job of paying too much for it but it's not that bad . Just don't tell me I got took - That's the story of my life , I trust everyone . Ya know what W.C. Fields said ( or was it P.T. Barnum ? ) about suckers - I represent that statement ! I'm not able to change now ! Take care ...Randy
Post a Followup
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
