Re: This question is electrical !
Posted by John T on November 12, 2005 at 21:42:37 from (66.244.90.98):
In Reply to: This question is electrical ! posted by Randy-IA on November 12, 2005 at 21:17:21:
Randy, Although I cant say for sure exactly not knowing how someone may have jury rigged your switch n system, if the Alternator is an internally regulated unit, such as a GM 10 SI, it doesnt require any external voltage regulation (it does require an excitation voltage circuit to its lil No 1 side terminal, see below) and WOULD NOT need to be wired to the combination light and field control charging system switch (L H B D) like they used for the old 2 wire cutout relay charging systems. The resistors in that type of combo regulatign switch suppled EITHER a dead ground for the Gennys Field for High charge and a ground via a resistor on that switch for Low charge. It can still be used as a light switch if its good, but its not needed nor wired to an internally regulated alternator. I have seen the GM 10 SI 3 wire alternators jury rigged up all sorts of ways to excite their fields/rotor so its no telling what you may have and how your switch and alternator is wired now. When I wire the GM 10 SI I use a 10 ohm current limiting protection resistor and a diode if needed in the excitation circuit, but I usually feed that off the Ignition switches IGN terminal or off the coils high input side. Most alternators are for Negative ground, in which case one has to rewire the coil and swap ammeter leads if it was an original Positive ground tractor. YOUR SPECIFIC QUESTIONS:
Soooooooooo, NO you do NOT need to adjust the charge rate of an internal regulated alternator.......... It shouldnt matter if its in the L or H position, cuz theres no Generator wired to it, and therefore its resistor (Low charge) or its dead grounding (high charge) positions are of no consequence for your alternator, they were for a generator.
You mentioned a resistor and a coil?????? If its a resistor in series with your Ignition Coil, they may have used the old original 6 volt coil and needed a voltage dropping (12 to 6) Ballast Resistor in series. Its wired after the ignition switch and ahead of the coil if its an ignition ballast resistor. When I rewire for an alternator that had a genny previously, I replace any 12 gauge wire in the charging circuit with 10 gauge. Post back any question, good luck n God Bless John T, retired electrical engineer
Home
| Forums
Today's Featured Article -
Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
