Some of the time it is a bad seat, some times it is a loose seat, Sometimes the float is filled with gasoline. Sometimes it is the float rubbing on the bowl, Sometimes it is the needle getting stuck in the seat bore. I would try to test by removing the bowl, and (as someone brilliantly noted on this site) put a clear shallow bowl or jar under the carb up around the parts substituting for the cast bowl, and turn on the fuel. If it does flood higher than the setting, it is clear why. The only exception is rubbing on the bowl. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
