Re: Mag Switch
Posted by MagMan on February 02, 2006 at 18:04:18 from (205.188.116.133):
In Reply to: Mag Switch posted by Elk Farmer on February 02, 2006 at 15:45:54:
Hey there elk farmer thats no problem. Just take the two screws out of the part on the side of the mag unhook the cable. Then pull it off there should bea nut underneath with a hole tapped in it for a small screw bolt. If not I can send you one then hook a wire up to it run it back to the seat and you find an on and off pull switch and hook it up or any kind of switch that would ground to the tractor when you switch it. Or you can do what I do and just take the wire wrap it around the light and ground it when you want it to quit. I would really like one of those switches for my 40 H if you want to part with it.
JON
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
