Re: Rear Rim Size/Tire Size
Posted by CNKS on April 08, 2006 at 14:43:46 from (204.249.178.138):
In Reply to: Rear Rim Size/Tire Size posted by Elk Farmer on April 08, 2006 at 06:59:13:
You need to measure your rims, and/or the other set you are looking at. What the tire says is the recommendation for that tire. It does not mean that they are actually mounted on that particular rim. I bet the rims you are looking at are ll inch. Are the tires actually 12-38, or 12.4-38. The old designation for 12.4-38 is 11-38. You can likely go one inch on either side of the rim designation without problems. Rim size 2 inches bigger than the tire size, no.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
