Farmall 130 coil problems
Posted by Ray D on May 26, 2006 at 18:55:13 from (205.188.116.133):
I have a farmall 130 that has been converted from 6 volt to 12 volt. It appears that it was positive ground due to the fact that the ground wire is red. I currently have the battery hooked up as negative ground. I put a new coil on the tractor and it runs good at first then the coil burns up. Should I reverse the wires on the coil by putting the negative on positive and positive on negative.The new coil had an internal resistor and it still burned. Any help would be appreciated. Ray
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
