Re: Farmall 130 coil problems
Posted by Bob on May 26, 2006 at 19:37:11 from (64.21.249.40):
In Reply to: Farmall 130 coil problems posted by Ray D on May 26, 2006 at 18:55:13:
Positive ground = Ignition switch to (-) on coil, (+) on coil to distributor. Negative ground = Ignition switch to (+) on coil, (-) on coil to distributor. That being said, it is unlikely the polarity being reversed is burning out the coil. Having the polarity correct simply makes for a hotter effective spark. Coils do NOT (with very few exceptions) have on "internal resistor"). A coil truly designed for 12-Volt use simply has more primary windings to function with 12-Volts. Bad spark plug wires, including the coil wire, can cause coil failure. A bad condensor MAY have some effect on the coil. Also, the coil will run hotter if the point gap is less than "spec". Also, have you checked the charging system voltage to be sure the 12-Volt system is not overcharging? Battery voltage readings much over 14.5 Volts, or so, with the engine revved up a bit indicate overcharging. What is the make and part number of the coils that have been failing? Lots of folks are having good luck with the NAPA part # IC14SB, which is a TRUE 12-Volt coil.
Home
| Forums
Today's Featured Article -
New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
