Bob M or other electrical guru, tractor won't stay
Posted by chadd on November 18, 2006 at 06:11:46 from (4.188.128.43):
Hi guys, still working on that 2500A that I posted about last time (would fire for a second and then do nothing). Well, I must be doing a good job fixing it, because now I got it so it won"t run at all. I started doing continuity tests on some of the wires. What I find is with the key in the run position and the continuity tester between the pos. terminal of the coil and the positive terminal of the battery cable, the tester makes a nice continous beep. What seems odd is that if I take the connection off of the positive battery terminal and then hook it up to the negative (ground) battery terminal it also makes a nice steady beep when the other lead is still connected to the positve coil post. It has an automotive style key (turn to detent to run, turn further to engage starter) If I turn the key switch to the start setting (to make the starter engage), there is no beep between the positive battery terminal and the positive coil post and there is a beep between the negative battery post and the positive post of the coil. I am having a heck of a time figuring out what is going on. I"ve found that the fuel solenoid works properly, but is wired through the coil connections, so that if there is no power to the coil, there is no fuel leaving the carb either. Am I testing the starting circuit correctly, and does the info above seem normal? Thanks, and sorry for the long post. Chad
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
