Re: Bob M or other electrical guru, tractor won't
Posted by Janicholson on November 18, 2006 at 06:46:22 from (66.173.50.86):
In Reply to: Bob M or other electrical guru, tractor won't stay posted by chadd on November 18, 2006 at 06:11:46:
A continuity check is OK for some things, but live circuits may not give readings/listenings that mean what you think they do. Assuming several things I do not know, I will advise the following. The coil is grounded through the points so a continuity check from ground to either side of the battery to the coil (either side)will produce "noise" when the key is on. The easiest way to prove operation of major parts might be to hot wire the coil. Place a long jumper between the positive battery post (at the battery), and the positive coil terminal. This should produce a click of the fuel shutoff, and provide ignition voltage. Crank the tractor now and see if it runs. If it does, you know it is the supply side of the system. If not it needs further analysis in the points and condenser/coil. If it runs, the issue is the wiring/key. The wire that supplies power to the tractor from the solenoid (attached to the battery side of the solenoid) is a #10 wire going to the amp meter (if it has one) then to the ignition Key. Check to make sure there is battery voltage at the key with a Volt meter. If yes turn the key on and test the voltage at the coil and fuel shutoff solenoid. They should have voltage now. If not it may have an ignition resistor that is bad, or going bad and intermittently touching internally (one of the problems not detected with a contenuity tester), or it may have a bad ign switch or wire to the ign. If yes it should run when turned over by pulling the tractor or cranking it by bypassing the starter solenoid with Fat wire jumper cables. If it does, the key switch may be bad internally not giving voltage to the coil when in the start position of the key (it happens). If there is a fourth connection on the start solenoid with an I on it (stands for ignition) that wire should go to the Pos side of the coil, (not to the resistor). If there is no terminal, ignore this idea. I hope this helps, let us know. JimN
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
