Still no attempt to start
Posted by ToddH on January 02, 2007 at 17:38:09 from (71.207.25.211):
Hi, I took advice from an earlier posting for the starter on my 1953 super C. I cleaned the communtator. The brushes are good with adequate spring force. The sleeve bushings are good. The armature can be rotated by hand easily. Now (unlike before the cleaning), when I connect it directly to a good battery it spins up very fast but it does not try to torque out of my hand as someone said it should. I mounted it and cleaned all connections including battery and grounds but no attempt to crank. Then I realized that when I pull out the starter switch, the amp meter goes slightly neg (as always) but as soon as I trigger the starter the amp meter goes back to zero and there is no sign of any attempt of starter turning. I checked the voltage regulator and contacts look good and not welded closed. Now when I pull out starter the amp meter doesn’t even go slightly negative as just mentioned. I thought maybe I should buy a new starter switch and fuse (probably good to have on hand anyway). Any comments on this and also if the improvements of the starter are adequate or should I also pursue a shop to rebuild. Any suggestions where to buy parts? Thanks so much for all of your suggestions and may your New Year find you well! ToddH
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
