Re: Still no attempt to start
Posted by teddy52food on January 03, 2007 at 06:54:00 from (204.73.107.177):
In Reply to: Still no attempt to start posted by ToddH on January 02, 2007 at 17:38:09:
Do you still have the short ground cable that goes to the box under the steering shaft? If so, that is maybe the problem. Try using a good heavy set of jumper cables (use both cables) from the battery ground to the starter mounting bolts. If it works then, that is your problem. Over time corrosion forms a resistance between the box and the casting. I run a good heavy cable direct from the battery to starter on more than one C & they spin over much faster.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
