Re: M won't start.
Posted by Janicholson on July 07, 2007 at 14:23:27 from (66.173.50.179):
In Reply to: Re: M won't start. posted by 40 acres on July 07, 2007 at 13:41:35:
Steps to take: (assuming volts to the coil are present) Remove the little wire from the side of the distributor. Remove the coil High voltage wire from the middle of the dist cap. Get a good condenser and use a jumper to ground it's body to the tractor. Attach the condenser lead and the lead from the coil together with another jumper. Put the coil high voltage wire 1/4" away from the engine block (tape helps). Turn on the ignition switch and then make and break contact with the block with the loose end of the jumper. It will spark a bit there, but it will produce a good spark (hopefully) proving the coil is good. If no good, replace the coil. If good it is in the points and condenser. JimN
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
