Re: Help on wiring of an M
Posted by Janicholson on July 09, 2007 at 16:41:45 from (66.173.50.173):
In Reply to: Help on wiring of an M posted by Mifsud on July 09, 2007 at 16:18:25:
Do not Use the resistor (I would take it off to reduce the clutter). Using it will result in bad spark. The neg wire goes to the distributor post with the nut and insulated washer (which connects to the points and condenser inside. (be sure to keep it insulated at the hole through the distributor.
JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
