Re: Farmall 450 Head
Posted by RustyFarmall on July 19, 2007 at 05:40:54 from (66.43.253.26):
In Reply to: Farmall 450 Head posted by Billm on July 19, 2007 at 05:28:30:
Remove the bolts that hold the head to the block and lift it off. Nothing else needs to be removed, although it will be easier to reassemble if you do remove the rocker arm shaft first. You also want to pull the pushrods out. The valve clearance will need to be re-set when you replace the head gasket. That head is heavy, get some help, or use a cherry picker. One man can carry it once it is off, but getting it up off the studs can be a bit of a chore for just one man.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
