Posted by John T on August 28, 2007 at 17:58:35 from (66.244.83.147):
In Reply to: farmall cub starter posted by farmallcollectr on August 28, 2007 at 15:51:57:
Are you jumping it with another 6 volt battery or a 12 volt??? If with another 6 volt your tractor battery may be bad or it might just need a recharge. If you jump a 6 volt starter at 12 volts they usually (unless starter is shot) spin real fast. Id take the battery to an auto parts shop cuz they usually will check n load test it for free then you will have a better handle on if its a battery or starter problem.
Just to make sure I would first remove, clean n wire brush, n reatatch each n every battery n starter n starter switch n ground cable connection cuz if any are bad it can cause poor cranking. Heck you may just need the battery charged and cleaned up cables n connections????
Try the easy simple no cost things first like clean all the cables n connections n charge up the battery and/or have a shop check n load test it. Then if all that fails you may have a starter switch or finally yes a starter problem...
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
