I'll bet your tractor is wired wrong. Have you traced out the wiring following a wiring diagram?
The action you describe could indicate the ammeter is hooked up backwards, and the lights are wired to the battery side of the ammeter.
The ammeter should be the first thing from the battery, except for the wire to the starter. If the lights have been wired to the starter post then they will draw through the ammeter. If the ammeter is backwards, current to the battery would show discharge, so if when battery is charging and when lights are turned on, there is even more amperage, so more indication of discharge.
Does the ammeter show discharge when the lights are turned on with the tractor off? It probably shows nothing, because the current does not have to pass through the ammeter.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
