Yes I have checked the wiring diragrams to make sure its hooked up right and it seems to be. Way its wired is from VR Batt terminal a wire goes to the AmpM to the post on the discharge side. Then a wire goes off the Charge side post of the AmpM to the starter. These are the only 2 wires on the AmpM. From the VR where it is marked L terminal the wire goes to the ignition pull switch. The amp meter does show discharge when lights are turned on and tractor is not running. Will take the diragram out and check the wires again.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
