Posted by Brian Jensen on October 02, 2007 at 12:20:27 from (207.176.229.92):
Ok, I pulled the valve cover off and was unpleasantly surprised with a little bit of coolant in a couple of the recesses by the valves, it was a minute amount and by no means does it look to have mixed with the oil at all maybe a teaspoon, I also checked my upper rad hose while I was standing on the tractor and noticed a little split in it which I guess if the gasket was not seated correctly or worn out could have caused a little coolant to get in. All of my valves are moving when I crank the engine and nothing appears to be bent or broken. What kind of problem could I potentially be looking at in regards to the coolant? A cracked head or am I making a mounain out of a mole hill? Now that I have it off I know I can use the tune-up specs to adjust the valves can anyone else tell me which of the tractors in the list have the same engine as mine? 264 CID I think as it by emblem is a W450D but has a W400D engine in it. What kind of feeler guage do I need?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
