Posted by Janicholson on October 02, 2007 at 13:06:37 from (199.17.6.122):
In Reply to: Valve Adjustment Saga posted by Brian Jensen on October 02, 2007 at 12:20:27:
Putting 6 psi (maximum) into the radiator with a cork/plug th make a seal, will cause coolant to be able to go through cracks and into places that show leaks. If pressurized, the pressure should stay for several hours. Green in the head (unless spilled there is manditory to repair(or stop the leak). Heads on these can crack from hot shutdown, low coolant, and freezing. Rep[air is possible, and done quite often. Good heads are hard to find. Drain a bit of oil out of it to see if any is under the oil in the Crank case. Use a flat feeler gauge to adjust the valves. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
