Good post, but the one statement of a thermostat making the engine run warmer isn't always true. It may not be applicable to tractors, but in some automotive applications a thermostat will make them run cooler. The theory behind this is that the thermostat, when open, slows the coolant flow, allowing the coolant to spend more time in the radiator, which allows more heat to be removed from the coolant. In other words, with no thermostat or other restriction in the system, the coolant isn't able to stay in the radiator long enough to be cooled properly. Might not be a big enough factor to show any difference in a low-rpm tractor engine though.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
