Posted by SDE on October 30, 2007 at 16:31:46 from (207.118.218.174):
In Reply to: 450 CLUTCH ? posted by Hoss357 on October 30, 2007 at 04:25:48:
My pressure plate had about .03 wear from a button clutch. I would assume that the flywheel had that much also. I had the flywheel ground for about $25 and trued the P.Plate myself because they could not do it. A normal clutch disc will be a little larger outside diameter and the inside diameter will be smaller. You could replace a normal clutch disc with a button clutch, but not a button with a standard disc, unless you have flywheel and P.P.trued up. I had two tractors apart this summer an had one of each style clutch to compare to each other. If I am wrong, I hope someone will say so. SDE
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
