Hugh, I can answer that. Engineers found out by testing and consumer input, that if a 12v system coil was designed to have neither an internal or external resistor, the reduction in starting voltage from the starter draw would reduce the coil output enough to compromise the starting capability. So automakers, and eventually tractor manufacturers. installed systems to compensate. They ran two wires to the ignition, one from the starter relay/solenoid directly to the coil, and one through the ignition switch to a resistor (Ford used a pink wire in the loom that was a resistor, while others used a block ceramic resistor)
The resistor bypass wire (that was connected to a terminal often labeled "I" on the solenoid or relay) allowed the 10 volts, of the remaining battery volts, to power the coil above the normal run voltage of the coil 10 volts on what is essentially a 6v coil. this raised the output at a time it was most needed, starting.
Another method of doing this is to use a thermal resistor that starts out cold and has low resistance, then gets hot and resists down to the 6v range. These can be internal (most) or external, allowing a simplified wiring system and about the same results. Seasons greetings from central MN Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
