Excellent, as an aside, on some makes of tractors that used a saddle starter mount mechanical push to start switch instead of an electric solenoid, the ballast by pass feature was achieved by an extra lil small terminal on the side of the starter switch which was hot ONLY while the switch was engaged. A lil wire was ran from there up to either the coils input or ballast output terminal (same ponnt electrically)......... Sooooo many of those got disabled over the years either cuz the wire got left off or disconencted or else the switch was replaced with one a lil cheaper that lacked that extra lil side terminal.....
As you well explained, that feature could really improve cold weather starting cuz when its cold the battery is less efficient PLUS the engine is harder to crank and the high starter current draw drops battery voltage drastically causing a weak spark WHEN YOU NEED IT THE MOST
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
