Re: How to remove Farmall H piston sleeves
Posted by M5G on January 05, 2008 at 09:43:34 from (64.12.116.73):
In Reply to: How to remove Farmall H piston sleeves posted by Diocona on January 05, 2008 at 09:31:46:
They are wet sleeves.
To get them out you will need a sleeve pulling kit and pull them from bottom up. The bottom of the sleeve puller has a built in flange to catch the sleeve without doing damage to the sleeve. Of course the pistons need to be removed for the puller to be used.
You might want to use some PB Blaster or any other rust type solvent -- kerosene works too to loosen the rust...tap with a wooden block on top of the sleeve after lubcating to get the rust to break loose (it might be good to even soak for a couple days before trying to remove them)
Lots of Luck! Go slo and easy!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
