Posted by Jim Becker on February 24, 2008 at 19:41:47 from (71.170.14.36):
In Reply to: magneto removal from W4 posted by Canadian Ken on February 24, 2008 at 18:42:23:
The easy way to remove and replace:
1. Hand crank the engine until you hear the impulse coupling click.
2. Scratch a small witness mark across the mag mounting flange to the engine block.
3. Take the distributor cap off and note which way the rotor is pointing.
4. Unbolt the mag and go do whatever needs to be done to it. DO NOT TOUCH THE ENGINE WHILE THE MAG IS OFF. LEAVE IT WHERE IT SITS.
5. When ready to remont the mag, turn it backwards until the rotor is pointing where it was at step 3.
6. Bolt the mag back in place and line up the witness mark.
7. Rotate the engine to verify the impulse clicks at TDC. It is unlikely that you will need to do any adjusting.
If you don't want to add scratch the witness mark, the impressions in the old gasket will probably be good enough. Without either, you just need to adjust the timing per the manual.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
