Re: How do you check transmission bearings?
Posted by riverbend on March 21, 2008 at 17:28:47 from (208.160.33.166):
In Reply to: How do you check transmission bearings? posted by CenTexFarmall on March 21, 2008 at 13:37:03:
I usually look for mangled chunks of bearing cage, bearings with missing balls, etc.
If the bearings are not rough, they will probably be okay. New heavy duty bearings will cost you $50-$100 depending on the size and number of balls. If the cost does not put you off, it will not hurt anything to change out the 60 year old ball bearings. Replacing them later is twice as much work as replacing them now.
The one bearing that I would replace is the input shaft pilot bearing. It seems the most likely to fail.
I have never heard of swapping sides with the bull gears. It sounds like it might just work. You could always try it and let us know what happens. Myself, I like to keep everything in its original place.
I hate it when things go wrong with my H, but it is surely a pleaure to work on.
Greg
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
